494 seed plate cell sizes
Tom Brown
11-27-2003 10:47:44
Hi, I've posted this on the implement ally board but came up dry. Does anyone know what dimensions the cells were in the seed plates to plant pumpkins and squash ? I've talked with people who remember it being done years ago but no one remembers the plate cells and if anything was done to modify the seed knocker. The 494 owners manual lists plates for other vegetable crops but not pumpkins and squash. I have some steel corn plates that I would modify if I can find out info on cell sizes. Thanks for your time.
mike
11-27-2003 16:51:27
 Re: 494 seed plate cell sizes in reply to Tom Brown, 11-27-2003 10:47:44
I plant pumpkins with jd 71 units using the deere B27436 plate. It works well for medium size seed, however i bought a few extras and modified them to plant the larger and smaller seed.
Tom Brown
11-29-2003 03:19:45
 Re: Re: 494 seed plate cell sizes in reply to mike, 11-27-2003 16:51:27
Thanks for your followup, Mike. I checked with the local JD dealer yesterday and they still have that plate # in their system. I have heard of the #71 units but I have never seen them. Is the seed unit itself (seed knocker, etc.) any differant than the seed units on the 494 planters? For over ten years I have been using a 1 row old Powell unit and it takes "forever" to get the pumpkins planted. I'm considering using a 494 or 694 to modify it to a multiple row pumpkin ,squash, cuke planter. I understand what you mean about modifing plates for the differant sized seeds... I've had to do the same for the powell unit. What is the distance between the hill drop seeds on the JD plate? The powell unit drops at about 36" I'm located in western OH. Where are you? Thanks for your help.
Mike
11-30-2003 09:08:03
 Re: Re: Re: 494 seed plate cell sizes in reply to Tom Brown, 11-29-2003 03:19:45
Tom i'm not real familiar with the 494/694 planters so i cant say for sure exactly what all the differences are. I think the seed unit is similar as far as the plate drive and knocker, however the 71 unit is more of a specialized vegetable planter. The 71 has a sprocket gearing system that allows a very wide range of adjustment of your plate speed. It also has a removable drop tube for more accurate placment of small seed like carrots and beets. I had the same idea you did and modified a larger planter to do several rows at a time. I used a deere 184 and a deere 186w planter as these were made with the 71 units and are fairly easy to find around here. The plate # i gave you is the deere pumpkin plate. it is a 12 cell plate. The way i have my gearing set up for medium size pumpkins (howden,autmn king) I drop seeds about 18" apart. for large pumpkins (atlantic giant,prizewinner) i welded 6 holes shut and enlarged the remaing 6 so i would get less seed breakage. These will drop at around 36". I'm located in southeast michigan. Feel free to e-mail me direct if you have any other questions. I'd be glad to explain what all i've done to make these planters work. Mike [email protected]
