Identifying Cast wheels on JD 50.
Rich
10-01-2001 19:50:57
Greetings All,
I have a JD Model 50 and I looking for some help with the cast steel wheels. First of all the wheels are marked B3800R and I do not see these wheels listed in the JD parts manual for the 50. The steel wheels have 36 inch rims and tires on them. Does anyone know if these wheels were original equipment on the 50 and can you use 38 inch rims and tires on these wheels? Right now one rim and tire is in fairly poor shape and I would like to get it fixed but also at the same time get the tractor closer to original condition.
Regards,
Rich
Mike Aylward
10-01-2001 20:43:42
 Re: Identifying Cast wheels on JD 50. in reply to Rich, 10-01-2001 19:50:57
Rich, my guess would be that the original owner of the tractor traded it for a 520 and wanted to keep his 38" tires. It was not uncommon. Hope this helps. Mike
Kerry Miller
10-01-2001 20:26:08
I just went out and checked mine, it's a 1955 JD 50 LP. The cast hubs say F1500R (at least the one facing the light does...) but I didn't see a number on the rims. If you need any more info I'll check it in the daylight for you..
Kerry
