70D Flywheel Spacer
Moye
11-27-2003 10:11:07
The book says to remove flywheel spacer then remover timing gear cover. Am I missing something here? I have spent the last two hours trying to get the spacer to move. I've tried a puller (can't get behind it), pry bars (still can't get behind it) and even talking to it (nicely and maybe not so nicely). I'm fixing to eat thanksgiving dinner. I give thanks that there are people like ya'll who will tell me what I am missing here. Happy Thanksgiving from way down south. Moye
DON
11-28-2003 08:36:29
 Re: 70D Flywheel Spacer in reply to Moye, 11-27-2003 10:11:07
SNAPPING THE CLUTCH IN AND OUT WILL USUALLY MAKE THEM MOVE.
Clooney
11-27-2003 10:33:59
Moye, if you find an easy way to get that dang flywheel spacer off let me know..
~I have tried a bunch of different ways & so far heating it with a torch, then working some penetrating oil in under it, then turning it with big vise grips seems to be best [don't use too much heat as that can destroy the fiber thrust washer under it] . Once it is turning a little you can turn it while lightly prying out on the timing cover & it will usually work out along the crankshaft.... Caution: don't pry on that timing cover too hard..
~I think that rubber ring gets hard & causes it to hang up.. They go back on a lot easier than they come off..
[email protected]
Moye
11-28-2003 05:33:57
 Re: Re: 70D Flywheel Spacer in reply to Clooney , 11-27-2003 10:33:59
Thanks, Clooney. I agree, it is tough. My Brother-in-Law and son-in-law came over for Thanksgiving dinner and with their help and three good prybars we finally got it to move. Once it moved, it was no problem. Thanks for the reply.
