Checking transmission oil level in Model B
Bob Weber
09-30-2001 08:58:26
Is there a way to do it, or do you just drain, flush, pour in 4 1/2 gallons and let it be? I can't find any info on checking the level in the Operators manual, nor can I find a level checking plug on the transmission case.
Chuck
09-30-2001 09:48:47
 Re: Checking transmission oil level in Model B in reply to Bob Weber, 09-30-2001 08:58:26
simple, when you fill the case, filler plug is at the lower rear at an angle, when it starts overflowing it is at the correct level.
Bob weber
09-30-2001 10:05:03
 Re: Re: Checking transmission oil level in Model B in reply to Chuck, 09-30-2001 09:48:47
Chuck, thanks. How stupid am I? The only time I ever refilled the transmission was when I had the cover off the top of the transmission, and I just dumped 4 1/2 gallons into the top.
