JD No. 44 two-bottom 14 plow parts needed
Dan Malinowski
09-30-2001 05:20:40
I am looking for a set of plow shares. There is not much left of the set that I have. Any info on repair or replacement would be greatly appreciated
ET
10-01-2001 08:33:36
 Re: JD No. 44 two-bottom 14 plow parts needed in reply to Dan Malinowski, 09-30-2001 05:20:40
What botoms do you have are they syracuse or john deere? What numbers are stampet or cast int the bottoms?
Dan Malinowski
10-02-2001 05:25:14
 Re: Re: JD No. 44 two-bottom 14 plow parts needed in reply to ET, 10-01-2001 08:33:36
Will I be able to see these numbers without removing them? I looked last night but didn't find anything yet. Part of my problem was the light was not the greatest. I will give it a good cleaning today and see what I can find.
Thanks
ET
10-02-2001 06:12:39
 Re: Re: Re: JD No. 44 two-bottom 14 plow parts needed in reply to Dan Malinowski, 10-02-2001 05:25:14
Syracuse bottoms will have 1441 or 1451 where you can read it on the back of the moldboard. Most of these bottoms have a replacable shin also. The John Deere bottoms are all steel with no replacable shin the number should be readable on the back of the points. The last time I priced ths points for the JD bottoms they were $65 each. The local dealer should have a separet parts book for the plow bottoms but if you post back some of the numbers off the back of the shares I may be able to tell you what you have. The numbers will be on
the back of the syracuse shares also.
Dan Malinowski
10-02-2001 19:15:20
 Re: Re: Re: Re: JD No. 44 two-bottom 14 plow parts needed in reply to ET, 10-02-2001 06:12:39
Ok I finally got a good look at this. On the back of the share is: BHA366A and on the back of the moldboard is: CY14B and this appears to be a JD moldboard. It looks like I will also need a landside. One of them on the ouside plow is completely worn away and broken off.I was not able to find a number on that one. The moldboard on that side is also in rough shape. Lots of welding and the leading edge is worn down past the top of the share. I guess all this might explain some of the trouble I have been having with that outside plow. I'm not sure of the vintage on this one but it has a steel rear wheel and spoked front wheels.
Thanks
Dan
ET
10-03-2001 11:23:34
 Re: Re: Re: Re: Re: JD No. 44 two-bottom 14 plow parts needed in reply to Dan Malinowski, 10-02-2001 19:15:20
Dan this will sound crasy but that number share is for a 16" slat bottom plow. However the same bottom is a 14" bottom with a different point. The same 14" point fits JD NA bottoms part number BCA217A is a 14" point that is available for $85.51 each. The 44 plow frames could be set up two ways there is an offset to the plow standards that is the part the bottom bolts to. Stand behind your plow and see if the standards are set so they
spread apart or step togeather. the wide way is 16 the narrow way 14. If its 16 try Pn BCA218A The moldboard number didn't help it could be aftermarket. I wouldn't worry about the shin edge of the moldboard unless its wore into to frog. Not protruding as far as the new shares won't matter.
My e-mail is [email protected] Eric
