Extra hole in main case?
chris in WI
09-29-2001 10:36:15
The main case ('46 A) I bought to replace my bad-order one was identical to mine, except that there was an extra hole in the case. It was a small, pipe-threaded hole right below where the part number is cast into the case. There was a brass elbow screwed into the hole, with a fitting leading to a 1/4 in. copper tube, but the copper tube was pinched off. What could this have been for? I'm sure it was added on to the tractor, but all I can figure was it was attached to some sort of oil filter (?).
It may be worthy to note that the governor of the tractor that had this case had a "T" fitting on the oil pressure sending hole that was explained to me by the scrappy as "where the original owner added an aftermarket oil filter" which apparently was some sort of auxilliary filter.
Anyone know anything about this?
chris
