A Carb problem
nigelB
09-28-2001 15:53:32
took a 41A with a DLTX 53 out for a 60 mile road run all day it would tick over a treat but as soon as i moved the throttle it would open right out,we stoped and set off for the last 10 miles and i had no power not anough to pull a hen off its nest,
it is holding back at the top end and has a pinking note,iv checked the float height,fuel supply to bowl,plugs,mag timing,run drills through the ports inc the famous 3?,valve clearances,cleaned the nozzel ,im running out of ideas and still it wont pull off in high gear. yours at the end of there tether nigelB
John T
09-28-2001 19:55:03
 Re: A Carb problem in reply to nigelB, 09-28-2001 15:53:32
Nigel, kinda like Ol Clooney there, with the long road trip and chances to get crud in the sediment bowl and/or carb, I suspect a fuel flow problem maybe. U gotta get a good flow of clean gas into the carb bowl FIRST and then of course the carb has to be okay. Are you able to open the carbs power needle adjustment to where she over richens and black smokes out the stack????? If u got good flow to the bowl and can richen her out at the needle adjustment and she still lacks power, then I would clean or replace the plugs with Autolite 388, clean and adjust or replace the points and condensor, then take 2 aspirins and call us at the office on Monday. Good luck let us know Ol John T
Clooney
09-28-2001 17:02:40
nigelB, pull the drain plug (or petcock) on the bottom of the carb & make sure you have a steady pencil sized stream of fuel for at least 30 seconds. If ok there you might have an ignition coil, points or condencer going bad. Or if you fueled up at that last stop you might have picked up a load of bad fuel.
