JD 50 live PTO clutch repair
Ron
09-25-2001 10:26:17
I'm overhauling the PTO clutch with 6 new center-clutch driven disks and the two end-clutch driven disks. All of the driving disks have varying degrees of pitting (from rust) and a couple of those same disks have mild scoring where metal to metal slipping has occurred. I've polished the driving disks as well as I can and plan to use them as is. Any thoughts as to whether that will be a problem for use? I plan to use it to power a small baler and a sickle mower. Thanks.
buckeye al
09-27-2001 15:02:09
 Re: JD 50 live PTO clutch repair in reply to Ron, 09-25-2001 10:26:17
I'll offer my nickel's worth....
When you're using the PTO is not when problems will occur. The trouble will be when the PTO is NOT in operation. When the PTO is NOT engaged, these disks have to freely slide over each other. They have to open up enough to let oil from the pump flow between them & not produce undue friction or they'll wear out fast, need frequent re-adjustment, may drag constantly and might even burn. I've seen drive disks warp and burn blue as a gun barrel! Unless they're flat, smooth & show no signs of heat damage, I'd not return them to service. The unit is not really a lot of fun to work on & I'd not want to do it twice. In any case, be sure to properly align the oil passageways in the disks with the oil holes in the splined hub for proper lubrication and cooling while disengaged!
Good luck.
buckeye al
09-27-2001 14:59:50
Good luck.
Ron
09-27-2001 15:14:35
 Re: Re: JD 50 live PTO clutch repair in reply to buckeye al, 09-27-2001 14:59:50
Good information. Thanks buckeye al.
