41 Jd H Valves
Clay
09-23-2001 11:05:57
How would I free up the valves on my tractor. I can turn the engine over 80% but when the push rods go to open the valves it freezes up eveything. Also can you tell if the bearings on the crankshaft are any good with out unhooking the piston rods. if the valves were free it would turn by hand reaaly easy.
Roy
09-23-2001 16:57:39
 Re: 41 Jd H Valves in reply to Clay, 09-23-2001 11:05:57
Suggest you pull the head do a valve job and inspect the bearings.
Clay
09-23-2001 18:21:10
 Re: Re: 41 Jd H Valves in reply to Roy, 09-23-2001 16:57:39
Do you know a good place to buy parts to do a valve job
Roy
09-23-2001 22:56:40
 Re: Re: Re: 41 Jd H Valves in reply to Clay , 09-23-2001 18:21:10
Try Dennis Polk e-mail address is [email protected] or call i-800-795-3501 or your local John Deere dealer.
