Using pto for hyd. pump
Andy Wier
09-21-2001 11:27:33
Have just recently gotten interested in my Grandad's old 50. The family no longer farms and I managed to keep the 50 and two 4020s from being sold on the farm auction. I would like to make the 50 a little more usable and useful. I am going to build a front dozer blade and was wondering if the tractor would handle a pto driven hydrolic pump to run the cylinder for the front blade and handle an implement like a rear blade on the 3 point. I plan on using the tractors system for the rocker shafts and it is my understanding that if you use the rocker shafts the hydrolics ports for cylinders are not usable. Is this to much for the old 50?
Andy
John T
09-21-2001 20:45:08
 Re: using pto for hyd. pump in reply to Andy Wier, 09-21-2001 11:27:33
Andy, I dont believe that load (guessing though dont know its actual HP load) is over the torque and HP limits of the 50 PTO, just consider how big a load a bush hog or feed grinder may be. You are right though, if you use the rock shafts, then the remote hydraulics does not operate because the fluid is diverted to the cylinder that raises and lowers the shafts. Good Luck Ol John T
