JD 2130 hydraulic leak, whining noise
Troy in Alaama
09-21-2001 05:53:43
Hello all,
I recently purchased a 2130 and have found a substantial leak oozing out from under the steering wheel. After removing the wheel I found the flood oozing out from around the small seal located there. Is this indicative of a greater problem? I havent replaced the seal as of yet. Also when traveling uphill a whining noise developes and then increased while the tractor stops pulling!
After refilling the hydraulic fluid (with the fluid sold to me by a John Deere Dealer) the pulling problem went away. The clutch never slips during engagement.
I went to the local dealer to pickup a manual and the correct fluid for the hydraulic system, only to be informed that that tractor wasn't American and was not supposed to be here any way. He said however that he thought he could order a manual for me.
I have operated Fords mostly except for an incursion to Belarus (****%$#$%**) and thought that I was stepping up to a better tractor when purchasing this one. I have always respected the John Deere name as one that reflects quality and durability. Do I need to sell this one and try to purchase an American model or does the Deere name apply to the German models as well?
All responses to any of the issues will be appreciated.
Thanks,Troy
Bob W
09-23-2001 17:35:51
 Re: JD 2130 hydraulic leak, whining noise in reply to Troy in Alaama, 09-21-2001 05:53:43
I agree with the other post as to the reputation of the 2130. They were marketed here in Canada and remain popular. We had one at the in-laws and it did a pile of work including pulling a JD 7000 8 row narrow planter over 1000's of acres (a lot of people won't believe that but it DID happen). Your local dealer should be able to get parts etc for you-- the seal is maybe part of the problem--there are 6 o-rings down inside the column that are likley the fault. Hang on to that 2130!!
Troy in Alabama
09-25-2001 01:26:32
 Re: Re: JD 2130 hydraulic leak, whining noise in reply to Bob W, 09-23-2001 17:35:51
Thanks for the informative post, Cannonball and Bob, I have replaced the seal under the steering wheel and the leaking has completely stopped. Thanks for the words of encouragemnt Bob, I was seriously questioning my purchase, but your words of reassurance make me feel better about it now.
cannonball
09-21-2001 17:33:00
we have 2 2130 here...good tractors...get leak at steering fixed ...remove fluid ...pull screen ...clean it and replace it...replace hyd filter ...install new fluid and remember to check with tractor running...the tractor has good motor and drive train some people abuse the hi lo by using the lo to gear down instead of using brakes..if need any more information just e-mail me and i will try to help....have nice day may god bless..... united we stand
