JD 50 AB4568R dust shield
panningbros
09-22-2015 11:26:52
John Deere 50 first reduction dust shield #AB4568R. The book calls this a dust shield with seal.
Mine is a metal part only. Was there supposed to be some kind of a felt seal or something on this piece? They don't show this seal or a replacement number for a seal. Thanks!
Mike M
09-23-2015 06:57:01
 Re: JD 50 AB4568R dust shield in reply to panningbros, 09-22-2015 11:26:52
Be sure to center it when installing it. Leave bolts sort of loose trial fit pulley on and tap the shield until you can shove the pulley all the way in with the least amount of rubbing going on. Then carefully slide pulley off and tighten your bolts and lock wire.
BushogPapa
09-22-2015 19:52:54
I know...weird, but true..there IS NO Seal, but it does Work..!!
Ron..
Rich Duane
09-22-2015 12:02:03
Panningbros, If you look at the clutch pulley you will see a spiral slinger ,there is no seal.
Kent Petersen
09-22-2015 16:37:55
 Re: JD 50 AB4568R dust shield in reply to Rich Duane, 09-22-2015 12:02:03
there is a hole of sorts in the dust shield ,it go down
