Fitting required for FEL ind valve on PS trans??
Tx Jim
09-22-2015 10:40:15
Does anyone now the correct fitting part number to tee return from ind valve into rockshaft return line on a '64 4020 powershift tractor???? I think the correct pressure tee by brake valve is AN140263 . I think AT28379 is incorrect for a powershift trans.
Thanks,Jim
This post was edited by Tx Jim at 10:42:10 09/22/15.
long green line man
09-24-2015 18:36:15
 Re: Fitting required for FEL ind valve on PS trans?? in reply to Tx Jim, 09-22-2015 10:40:15
third party image
Jim: I just noticed your post on rockshaft return tee; AK40462 is JD part # for tee [we use]; used on both powershift & syncro tractors, .. AK40464 (sub AT28379)is elbow used on tee "ak40462" to route return hose from ind. valve to upright, vertical position ; steel rockshaft return on powershifts enters tee from top... I'll try get a pic of last powershift we did for a reference ... JD parts detail for AK40642 ..... another ref. Parts Cat. 1148 & 1447 Models 100K & 200 crop [sugar beet] thinner.. under hyd. return line tractor connectors.. /we plumed a lot of thinners to 4020's in the late 60's when thinners first came out..
Tim S
09-22-2015 11:57:59
I just pick them up at my Hydro shop,,not sure what the Deere number is..
Tx Jim
09-22-2015 13:19:33
 Re: Fitting required for FEL ind valve on PS trans?? in reply to Tim S, 09-22-2015 11:57:59
Thanks Tim
My neighbor asked me to get the part numbers for him. I agree hyd supply place would probably be the better place to get the fittings than JD dealer.
Jim
Mike Aylward
09-22-2015 13:44:26
 Re: Fitting required for FEL ind valve on PS trans?? in reply to Tx Jim, 09-22-2015 13:19:33
Jim, if you have the time and patience you can go to the JD parts site and look up the specifications of the fitting you need (if available) along with the part number. I used to do this frequently by book when I was a parts manager but it is now done online. Mike
Tx Jim
09-22-2015 14:09:09
 Re: Fitting required for FEL ind valve on PS trans?? in reply to Mike Aylward, 09-22-2015 13:44:26
Thanks Mike unfortunately I have the time but not the patience. I'll just allow my neighbor to go to hyd supply place to procure the fittings. I wish I had a copy of the book(IIRC Red Book) that contained JD part # crossover numbers & spec's.
Jim
This post was edited by Tx Jim at 14:11:50 09/22/15.
Mike Aylward
09-22-2015 15:55:07
 Re: Fitting required for FEL ind valve on PS trans?? in reply to Tx Jim, 09-22-2015 14:09:09
I know what you mean, Jim. It's much easier for me to find something in a book than on a computer. I surmise I am not alone...:) I have many John Deere books but that is one I don't think I have. Mike
MikeinKy
09-24-2015 18:55:34
 Re: Fitting required for FEL ind valve on PS trans?? in reply to Mike Aylward, 09-22-2015 15:55:07
Like this, I recently put a valve on my 4020.
third party image
Tx Jim
09-25-2015 04:30:34
 Re: Fitting required for FEL ind valve on PS trans?? in reply to MikeinKy, 09-24-2015 18:55:34
Yes similar. Where did you route the return hose(rockshaft return line or ported hyd filter cover). I want to route my neighbors '64 4020(powershift trans) FEL control valve return hose to RS line fitting and I was wanting a JD part # for a tee to replace this fitting so I could send neighbors employee to get necessary fittings. I know thread size I need is 1.062 IN just thought maybe someone knew part number.
MikeinKy
09-25-2015 07:21:16
 Re: Fitting required for FEL ind valve on PS trans?? in reply to Tx Jim, 09-25-2015 04:30:34
Mine is a powershift and there isn't a lot of room under the tractor, so I drilled and tapped into the filter housing for a half inch hose.
long green line man
09-25-2015 06:24:19
Jim : I route return hose under tractor just above & to back of mid pto , than back over hyd. filters covers to elbow fitting AK40464 used on 3020's,on 3020's rockshaft return line attaches to top of tee; On 4020's attach right to AK40462 tee, set a 10 o-clock position to meet return hose from ind. valve...
Tx Jim
09-25-2015 06:31:42
 Re: Fitting required for FEL ind valve on PS trans?? in reply to long green line man, 09-25-2015 06:24:19
According to JDparts.com AK40464 subs to AT28379
third party image
AK40462 appears it might fit the powershift tractor.
Thanks,Jim
