730 LP shift quadrant different....
mike-nm
11-26-2003 20:52:26
I was looking in the owners manual tonight and I noticed that my transmission shift quadrant is different then the one in the manual. My 2nd gear is in the place where the first should be,5th is where 3rd should be, first is where 2nd should be,3rd is where 4th should be and 4th is where 5th should be ! The only ones that are the same as the book is Reverse and 6th. What gives here? and what does it mean? My quadrant is even different then my service manuel shows. thanks to all who respond !!- mike-nm
mike-nm--- Thanks
11-27-2003 06:39:36
 Re: 730 LP shift quadrant different.... in reply to mike-nm, 11-26-2003 20:52:26
I was just curious. This tractor came off the cotton patch in Texas.
Clooney
11-27-2003 06:03:57
Mike, Mike H. pretty well covered the basic speed difference but there are still a few different set ups that could be in there..
~Deere offered a special 8 mph 5th gear & that required a different shift quadrant [that is what you have]..
~They also offered a special high speed 4th & 6th gear. That uses the original quadrant if installed by itself [the special 8 mph 5th is what drove the quadrant change].. That special 4th & 6th raised the 6th speed about 1 mph..It also raised the original 4th gear POSITION about 3/8 of a mph..
~Now that sounds like you just get a new 5th gear doesn't it? ....Well not exactly..
~What happens is: a new gear [overgear] is installed OVER the original 1st gear pinion, then a new sliding gear is installed to go with it.. What that does is:
>The original 2nd now becomes the new 1st...
>The new added gears now becomes 2nd....
>The original 4th now becomes the new 3rd..
>The original 5th now becomes the new 4th..
>The new added gears now become the new 5th.. [8-1/3 mph]
>The original 6th stays 6th..
> Reverse stays the same also...
~It is very easy to change back to the creeper first gear [that is what you lost with the new high speed 5th] all you have to do is pull the L/H side cover & remove the two bolts that hold the overgear on then install an original sliding gear & fork & you have your original gears back. The quadrant can also be changed or you can just re-mark the one that's there... If you also have the optional 4th- 6th that will be much harder to change back as the trans has to come apart..
[email protected]
Tony
11-27-2003 06:38:20
 Re: Re: 730 LP shift quadrant different.... in reply to Clooney , 11-27-2003 06:03:57
Will the sixth gear interchange with the different speed transmissions? Thank you
Clooney
11-27-2003 08:22:11
 Re: Re: Re: 730 LP shift quadrant different.... in reply to Tony, 11-27-2003 06:38:20
Tony, the optional 4th-6th ... can be installed without the optional 5th gear & quadrant.. The trans will have to come about completely apart though.. That will change the published speeds from 4-1/3 to 4-7/8 in 4th & change the published speeds from 11-1/4 to 12-1/4 in 6th..
~If you are just looking for a higher road speed just install larger tires.. going from the production 15.5X38 to a larger 14.9X38 will make a noticeable difference in road speed.. Going to the 16.9's will really make it fly..
[email protected]
720Deere
11-27-2003 09:09:40
 Re: Re: Re: Re: 730 LP shift quadrant different... in reply to Clooney , 11-27-2003 08:22:11
I can vouch for the 16.9-38 road speed. My 720 will run somewhere around 16 mph with 16.9s.
Why is the 15.5 such an odd size? You would think that they are bigger than 14.9, but the 14.9 has a larger diameter and a larger footprint. I didn't believe this until I checked the Firestone web site.
Tony
11-27-2003 08:32:03
Thank you for the info. I've got a parts tractor that has the 1st gear in the upper left slot. I've got a 720 that the 6th gear has a ticking sound in it. The tractor with the 6th gear problem must be the slower gear transmission.I was hoping the 6th gear from the parts tractor would interchange with slower gear transmission. Thank you very much for your reply.
Clooney
11-27-2003 08:40:40
 Re: Re: Re: Re: Re: 730 LP shift quadrant differen in reply to Tony, 11-27-2003 08:32:03
Tony, just count the gear teeth. If you have 27 & 21 you have the optional 4th- 6th.. If you have 26 & 21 you have the production 4th-6th gears. In any case they will swap over, just make sure you use both gears..
[email protected]
Tony
11-27-2003 08:49:14
 Re: Re: Re: Re: Re: Re: 730 LP shift quadrant diff in reply to Clooney , 11-27-2003 08:40:40
Thank you and Happy Thanksgiving !!
MIKE HANLEY
11-26-2003 23:35:08
JD had what could be called the standard trans in the 730 that was. 1st gear 1 1/3 MPH 2nd gear 2 1/4 MPH 3th gear 3 1/2 MPH 4th gear 4 1/3 MPH 5th gear 5 3/4 MPH 6th gear 11 1/4 MPH This took quadrant casting # AF 2843R. This was the transmission that was in the 720 when it was tested at NEB. The opitional trasmission was 1st gear 2 1/4 MPH 2nd gear 3 1/4 MPH 3th gear 4 1/3 MPH 4th gear 5 3/4 MPH 5th gear 8 1/3 MPH 6th gear 11 1/4 This took quadrant AR 20133R Tractors with the slower transmission are commonly called ones with "CREEPER GEARS". and the ones with the higher speeds were commonly called "HIGH SPEED" transmission or sometimes called "Opitional 5th 8 MPH gearing."
MIKE HANLEY
11-26-2003 23:56:27
 Re: Re: 730 LP shift quadrant different.... in reply to MIKE HANLEY, 11-26-2003 23:35:08
It seems that over the years I have seen more 720's with the creeper gear then the high speed transmissions and more of the 730's with the high speed transmissions rather then with the creeper gear. Both our 730's have the high speed transmissions. The kids rake hay in 5th (8MPH) with JD 567 wheel rakes. My back will not take that speed
720Deere
11-27-2003 04:49:29
 Re: Re: Re: 730 LP shift quadrant different.... in reply to MIKE HANLEY, 11-26-2003 23:56:27
Hey Mike,
How's that 730 rebuild coming along? Have you had to mortgage the ranch to pay it's bills yet? I was just curious, keep us updated.
MIKE HANLEY
11-27-2003 08:03:04
 Re: Re: Re: Re: 730 LP shift quadrant different... in reply to 720Deere, 11-27-2003 04:49:29
As of this week all the parts are here and the block is back with the new sleves. HOWEVER this is DEER season in Wisconsin and the mechcanic is out trying to get a deer. He's hunting over on the goverment land at Wildcat Mountain. On our place we are all done by noon opening day. The body shop called the other day and he has the hood and nose cone for the 630 is done. Will drive the 630 down monday, put the ood on and then tuch up and put the new lettering on it. It's snowen but hasn't stuck, so the cattle are still on the ridge, Can get by without the 630 till they come down bellering.
