350-B Crawler Track
Todd St.Jacques
09-18-2001 13:09:44
I have a JD 350-BB (crawler/loader) and have reached the end of the stroke on the hydraulic (grease filled) track adjusters. In fact I blew the seal out the end the other day when I was adjusting the track.
I know the best fix is to start rebuilding the undercarriage as the stretched and worn track pins and bushings are ultimately whats causing the problem. However when proper track tension is maintained (as specifies in the JD Manual) the tracks function remarkably well. (They never walk off, they never skip on the sprockets)
Well I cant afford to dump $1000's into new undercarriage & track parts to fix the problem.
Should I ...
Make a 2-3" long shim/spacer to go between the front idler and the grease cylinger to reclaim some stroke on the cylinder.
-or-
Attempt to take a single link out of the track. Is this very labor intensive using the Hammer & Heat Method?
Opinions/Suggestions would be appriciated!
Thanks
Todd S
CPeter
09-19-2001 09:06:17
 Re: 350-B Crawler Track in reply to Todd St.Jacques, 09-18-2001 13:09:44
On my old 40 tracks, I cut out one or two links and ran it that way. Take the links from the end oposite the end where the master pin goes.I used a torch to cut the link fron the pin. You might be able to take the pad off and then heat the link enough to drive it apart.
