John Deere A New alternater
doomed
09-18-2001 12:08:47
My dad has a JD A, the alt on it went bad, so he
bought a new alternator. The problem is that
there are two wires coming from the tractor and
the place he bought it from told him he only
needed to attach one of these to the new
alternator? i cant figure it out since I live 2
hours from him. how do you set these wires so the
batttery will charge correctly?
Craig
09-18-2001 13:06:06
 Re: John Deere A New alternater in reply to doomed, 09-18-2001 12:08:47
You did not mention what year tractor or serial number range. If it's a late A like my 1950 B then both wires connect to the alternator. On my B one original wire leads to the amp gage and then battery. The second wire connects to the headlight switch and originally was connected to the "L" (lights) terminal on the regulator for the old generator. I swaped a alternator on my B (It's even a 6 volt alternator too !!) for better battery charging purposes during my short infrequent use. I connected both wires to the output stud on the alternator and all works great.
Doomed
09-18-2001 16:36:05
 Re: Re: John Deere A New alternater in reply to Craig, 09-18-2001 13:06:06
Thanks for the feed back Craig & Clooney. When I
actually look at the tractor I will try to post
the info on the tractor and wiring. Thanks again
Clooney
09-18-2001 17:41:24
 Re: Re: Re: John Deere A New alternater in reply to Doomed, 09-18-2001 16:36:05
Doomed, if the regulator was removed with the generator you can hook it up like Craig did, but if the alternator is a high output you really should up the gage of the battery wire to 10 gage.
Clooney
09-18-2001 12:45:20
Doomed, neither wire attaches to the alternator. He will have to run a new wire from the old regulator (BAT) terminal or battery wire to the big BAT terminal on the new alternator, then if the old regulator has an (L) terminal he will have to either jump or hook it to the (BAT) terminal on the old regulator. If the new alternator is 50 amp or higher( a good possibility) he really should run a new 10 gage wire from the alternator to the amp meter & a new 10 gage wire from the amp meter to the starter or battery. I presume because it already had an alternator on it that it was converted to negative ground & the coil power wires was swapped to the + terminal on the coil.
Al
09-18-2001 16:56:04
 Re: Re: John Deere A New alternater in reply to Clooney, 09-18-2001 12:45:20
Clooney, If the tractor has been changed over in the past, how do you determine if it is positive or negative ground?
Thanks,
Al
Clooney
09-18-2001 17:38:09
 Re: Re: Re: John Deere A New alternater in reply to Al, 09-18-2001 16:56:04
Al, just look at the battery & see which post is hooked to the wire that goes to the seat box, frame or other solid ground, the post that goes to ground is the polarity of the system. If it doesn't have a battery then look at the coil & see what terminal the distributor wire is hooked to & that should be the ground polarity.
