F-M magneto on early '34 JD A
GPWT
09-17-2001 13:13:05
I am rebuilding the F-M DRV2A magneto for my early '34 A and have a problem as such:
When the impulse releases, these conditions must all exist:
1. The movable pole piece "lobe" in the armature must have a slight gap between it and the fixed pole piece. It must be moving away rotationally so it is at the point of greatest possible change in magnetic flux.
2. The points must be opening.
3. The segment on the distributor must be positioned at the brush under the tower.
I can rebuild the magneto so all of the above are true, but then the lugs on the impulse coupling are not horizontal. Normally, the drive coupling on the governer is set for horizontal lugs at impulse. What to do? Change the governer coupling position? Any other suggestions other than using a Wico?
