Clooney and JohnT
DaveWis
11-26-2003 19:54:09
I posted this under the B driver post but think you may not read it there. I have just pulled the 2 cyl flywheels on with the nut the last bit. Is there any reason to not do this? Also I recently found 1 wire alternators from a company in Canada called Wilson. I got it from my NAPA dealer. It has low rpm kickin, I just put one on a 630 and it kicks in about 100-200 rpm over idle. Do you know of this co.? Oh, I'm going to be in Indianapolis Dec. 3 through 7 for the PRI show. Do you have any pull to have good weather then? Anyway everyone have a great Thanksgiving.
DaveWis
11-28-2003 16:27:27
 Re: Clooney and JohnT in reply to DaveWis, 11-26-2003 19:54:09
Thanks all for the replies.
Clooney
11-27-2003 05:16:52
Dave, I don't usually recommend using that nut as most people don't have a BIG wrench or big channel locks to turn it with any force.. If I tell them to use the nut & they take a chisel to it that tears up that very expensive nut.
~You are correct though in that you can use the nut to move the flywheel in [I use it myself]...
~On the alternator... there are many different 1 wire units out there with some that do excite at a lower RPM. Most still require an engine rev up after starting to get them to excite though. There are a lot of people that do use one wire units without any problems..... Problem is, most of the one wire units are high output units that are in the 60 amp or higher range & those high amp units should have heavier wire run to & from the amp gage... The high output charging load coupled with the power steering pump load is really hard on those small fan shaft gears.. As long as the battery is in good shape & kept pretty well charged it isn't a problem as the alternator only outputs a small amount of it capacity..
Bob
11-27-2003 03:35:52
Wilson is in Winnipeg, and has a warehouse in Minneapolis, and perhaps others in the US.
Some of the best re-man electrical parts I've ever used.
What is the part # of the alternator you used?
DaveWis
11-28-2003 16:26:23
 Re: Re: Clooney and JohnT in reply to Bob, 11-27-2003 03:35:52
I'm not at home now so can't give you the part no. Will post back here with it tomorrow. I can only get dialup at home and am too busy to spend all my time waiting on the computer. So I do this at my work between jobs.
John T
11-26-2003 20:24:19
Hi again there Dave, No, no problem with using the nut to suck the flywheel in to her milk, Im just used to older stuff that doesnt have that luxury lol so its 2 guys on each side as I posted. Im unfamiliar with the company you mentioned, but the excitation at low RPM was a problem, so if you have one that works as you say and they are reliable, sounds good to me.
Happy Thanksgivign n God Bless
John T
