Seal for 720D hydraulics
KWB
09-15-2001 06:02:49
I nead a seal for the shifter handle for the powertroll pomp for a 720D, PN AF-2135 R. John Deere dealer says it's no longer avaailable there. Does anyone know of a substitute or another way to fix the leak? Thank you.
Fudd
09-15-2001 20:24:53
 Re: Seal for 720D hydraulics in reply to KWB, 09-15-2001 06:02:49
If you can, remove the seal and measure the ID of the bore and the OD of the shaft and go to a power transmission supplier, take the seal with you, and they should be able to match it up. They specialize in seals.
