John Deere 3140 creeper shift
Wayne Kachmar
09-12-2001 20:59:35
I have a JD 3140 I purchased at auction this spring. I finally located a shop manuel from JD for it. However there is no clear diagram of the "creeper shift" location. Is it possible that this slow speed transmission was an option and could not have been installed? Is there someone with info on where the shifter is located in the cab (SG2 type)? It would be very helpful to get any detail on this tractor (John Deere claims that this is a European model made in Germany and should not be here.) Any help on which US models parts fit on this model or interchange info would be appreciated.
davidval
09-14-2001 08:31:09
 Re: John Deere 3140 creeper shift in reply to Wayne Kachmar, 09-12-2001 20:59:35
the creeper transmission was an option on these tractors and was replacing the hi lo shift unit.
if you have hi low uou do not have creeper.
anyway,the creeper shift lever is in the bottom of the dash housing just above the floor.
david
