How do you post a picture
Green Envy
11-26-2003 18:21:25
I did read FIT's method on how to post a picture with your message but I don't see "properties" when I right click on the picture. Is there some other way to post a picture? Thanks
Jack B
11-27-2003 04:40:21
 Re: How do you post a picture in reply to Green Envy, 11-26-2003 18:21:25
I had a problem to, had to get another guy to come help me with it and we finally figured it out.I've only done it once and don't know if I can do it again.
Steve - IN
11-26-2003 19:40:26
third party image
Green Envy,
You should see a dialog box like this one when you right click on a picture. This one is from MS Internet Explorer, but the one from Netscape looks fairly similar. Properties is the bottom item on either one.
If you get no dialog box at all when you right click, and you're on a site other than this one; it's possible whoever made the page inserted a java script to keep you from using his pictures. In that case, click: file / save as / name the file and it will download the whole page, making a subdirectory with the photos in them. Upload the photo to this site, then start from square one -- making sure you haven't purloined any copyrighted material.
F-I-T
11-26-2003 19:10:02
Green Envy:
Let's go one step at a time.
What do you see when you "right" click? Anything?
If you go to the Photo Ads and bring up the first ad there, and you right click on the picture, you should get a drop down list, and at the bottom should be "Properties"
Are you runninng a PC or something else?
Give us a full report.
Frank
Green Envy
11-26-2003 19:36:37
 Re: Re: How do you post a picture in reply to F-I-T, 11-26-2003 19:10:02
I went back and tried it again and the properties bar showed up. Can't explain why it didn't the first 5 times. I tried posting a picture right after I put it in the tractor photo section. Maybe that has something to do with it. Anyways it works now and thanks for the help.
Tye
11-26-2003 18:30:18
Green, Go to PAGE 2 of the forum. Scroll down to about the middle of the page. There's an excellent description of how to post a picture.
