John Deer 720
Anthony Moran
09-10-2001 14:09:36
I have a J.D. 720 that needs to be rebuilt. It currently blows (oil or water) out of the exhaust pipe when running. I believe the cilinder walls are probably scarred up. My question revolves around whether this tractor motor has cilinder sleeves that can be replaced. Does this model allow for replacement cilinder sleeves???
Spokerd1
09-10-2001 15:46:03
 Re: John Deer 720 in reply to Anthony Moran, 09-10-2001 14:09:36
You can bore and sleeve this engine. The 720 does not have replacable sleeves. From what you discribe it sounds as though you have a crack in the head. Have the head check as it might be cracked around a valve seat.
rick
09-11-2001 10:12:58
 Re: Re: John Deer 720 in reply to Spokerd1, 09-10-2001 15:46:03
I agree. Check the head close. I cracked the #2
at the exhaust valve and blew water badly.
If you need to replace the head,check the board
for suggestions.I made a mistake with replacing
mine with a spare 730 head, but I needed the
tractor in the field.
Oliver L.
09-16-2001 21:59:17
 Re: Re: Re: John Deer 720 in reply to rick, 09-11-2001 10:12:58
This also could be a head gasket. I seem to blow one about every 3 or 4 years on my 730, especially when I'm chopping silage.
