Greg H.
09-10-2001 06:15:51
Re: new case of green fever in reply to keith, 09-09-2001 04:16:50
Keith, I'm not for sure because I've never fooled with a 2510, or 2520, but I've had occasion to fool with 3020's and a 4020 rowcrop tractors. If the 2510 is set up similar, there should be a clutch adjustment nut, that can be loosened, and allow you to reset your clutch peddle for the recommended 3/8 to 1/2 inch of clutch peddle free travel. From what I'm hearing from you, it sounds like your peddle is all the way back with no free travel. If that's the case loosen the nut, slide the clutch peddle forward, so that it has the proper free travel, tighten it back up, and take it for a test ride. If after adjusting it properly if it doesn't hold or if you have used up all the adjustment slot, I'd make plans to go ahead and split the puppy, and stick a new clutch plate in. I hope things work out, and I'm sorry about not being able to explain things better, but it's monday morning, and I'm not able to access my brain cells yet. Later, Greg H.
