410B Reverser won't go forward or reverse
Dan
11-26-2003 17:30:51
About 2 weeks ago the revereser stopped moving the tractor forward or reverse. Oil was off the stick, Filled the Hyd Oil and it seemed to work for about 3 hours, then quit altogether.
I am in the process of changing the filter, but need help finding the inlet screen that is supposed to be at the end of one of the Hyd Lines. Any Ideas on this whole deal would be appreciated. By the way, the Hyd oil didn't look to pleasant upon draining.
Thanks
Dan
Jonathan
11-26-2003 17:45:56
 Re: 410B Reverser won't go forward or reverse in reply to Dan, 11-26-2003 17:30:51
there are 2 dipsticks...one is for hydraulic level and transmission...the other is for the reverser...reverser oil level should be checked with engine running..the other stick doesnt matter ..either running or off as it doesnt change much...reverser has its own filter..check the clutch pedal linkage...its only an aluminum arm that connects to a valve on the side of the reverser...not a conventional "clutch". There are dissimilar metals there ...aluminum and steel...and tends to be corrosion at that arm...also with age they tend to break...its located on the left side behind the tim panel on the side of the fuel tank...above the battery box..
