Re: john deere froze up
Jerry S
09-06-2001 11:14:14
I have a B that someone tried to loosen the motor by pulling it. Now the crankshaft is bent and the drive pulley in the clutch is shot and the motor never did move from that. I pulled the head off and freed it up differently. Be careful that you don't ruin the rods and crank by torquing it too much could cost you more in parts than the tractor is worth. Besides if it is very tight, you might have to do major block work anyhow requiring block removal. Occaisionally one lucks out and can clean out the piston holes and the penetrating oil will go on and work.
