Power trouble in a 1951 JD A
John
09-04-2001 22:17:35
My cousin has a 1951 A and can't seem to get it to run right. It has .045 over aliminum pistons, a cam, ans minor head work done to it. It should run about 43hp onthe dyno, but it only runs 35hp.
When it runs, it spits and sputters (so he calls it hoppity-skippety) and it cant be the carb. They have tried 7 differnt carbs on it. If you have the slightest idea whats wrong, please tell me.
P.S. It ran 35hp with out the built up cam.
rollo
09-05-2001 09:22:19
 Re: power trouble in a 1951 JD A in reply to John, 09-04-2001 22:17:35
Can the air cleaner be clogged? Are the valves ok and adjusted correctly? Has the engine been broken in enough?(seated rings) Was the block rebored? Is the magneto firing correctly? Timing ok?
John
09-05-2001 19:03:49
 Re: Re: power trouble in a 1951 JD A in reply to rollo, 09-05-2001 09:22:19
I know the valves are good and seated. And I know that the air breather isn't cloged, but the others could be right.
They have adjusted the timeing alot and nothing changes it. The block isn't rebored again.
Thanks for your help rollo!
John
