JD LA Sparkplug Suggestions
Greengo
09-04-2001 20:24:19
I'm having a small sparkplug fouling problem on my LA. Does anyone have a suggestion for a hotter plug that they have tried. The H 10 Champion plugs are gas fouled.
Please give your suggestions.
Thanks
Greengo
Larry
09-07-2001 12:16:29
 Re: JD LA Sparkplug Suggestions in reply to Greengo, 09-04-2001 20:24:19
I have a 1945 LA. I was having trouble with plugs fouling. I finally got the timing just right, and haven't changed a plug since. That was four parades and about 10 lawn mowings back. I pull a 5 foot engine driven rotory mower with my LA to mow about an acre of lawn. I am currently using a Champion gold version of their J8 lawnmower plug. They are short and easy to get in and out, not that I am a big fan of champion.
M R
09-05-2001 18:12:41
John R. Brillman
P.O. Box 333
Tatamy, PA 18085
Phone: 610-252-9828
Fax: 610-923-6069
http://www.brillman.com/main.html
M R
09-05-2001 18:08:57
John R. Brillman
Mike Aylward
09-05-2001 10:32:33
Greengo, try using an Autolite 216 plug. This is the same plug a Dubuque series tractor uses and they work very well. I have used them in the "L" series tractors and the Dubuque tractors and they work well in all of them. Hope this helps. Mike
John
09-04-2001 20:42:26
I would sudjest D16 champion plugs for almost all tractor engines. There not to hot or to cold as far as I'm concerned.
Steven M
09-05-2001 04:22:44
 Re: Re: JD LA Sparkplug Suggestions in reply to John , 09-04-2001 20:42:26
D16 plugs will not fit a LA they are 18mm and the LA uses 14mm
John
09-05-2001 19:30:04
 Re: Re: Re: JD LA Sparkplug Suggestions in reply to Steven M, 09-05-2001 04:22:44
I have never worked on anny of thos types of tractors, just A's, B's, G's, GP's, 4020's, 3020's, 3010's, and that stuff. I didn't know that and thanks for making me aware of that!! Thanks, John
Eddie A
09-06-2001 18:29:24
 Re: Re: Re: Re: JD LA Sparkplug Suggestions in reply to John, 09-05-2001 19:30:04
why in the world would you post advice on spark plugs if you don't know anything about the tractor. i have noticed other posts of yours with incorrect information. incorect information will really screw somebody up.
