JD B (gas) float setting
Herb
09-04-2001 19:21:35
Can someone tell me what the fffloat setting is on a gas B. Thanks
Mike Aylward
09-05-2001 06:15:11
 Re: JD B (gas) float setting in reply to Herb, 09-04-2001 19:21:35
Herb, like John said the float should be level and set at 3/8" from the top of the float bowl. This should give you a fuel level of 3/4" below the top of the bowl. Hope this helps. Mike
John
09-04-2001 20:46:01
The float should be parralell with the top of the carb. bowl when you lightly pull up on it.
