AR Starter System
John in OH
09-04-2001 10:29:42
Recently I have aquired a 1942 AR. This tractor was originally built with no electric starter. I would like to add a generator and starter (maybe lights also) and would like to know if JD offered a "starter/electrical system retrofit kit" for these machines. I would like to use components that are as close as possible to the components that would have been used back in the '40s to make this upgrade.
Does anyone know part numbers, procedures, or anything about such a kit? Has anyone done a retro-fit? I assume that I will need a starter, starter mounting bracket, flywheel ring gear, starter pedal and switch, generator and mounting bracket, fanshaft pulley, voltage regulator, battery etc. Is there anything unique about the fanshaft pulley? I heard a rumor that JD made a split pulley for retrofits - true or not?? Anything you guys can offer to help me out will be appreciated!! Thanks, John
John
09-04-2001 21:09:53
 Re: AR Starter System in reply to John in OH, 09-04-2001 10:29:42
I know that the only thing I have been told is that along time ago(42-45), They made conversian kits. We have a bunch of two cylinder "A's" in the shed and it don't take any special starter, genrator, brackets, or that stuff. The 40's all the way to mid 1946 had top starters that were all the same. I don't believe deere made a special split pully, but you should be able to go to some scrap yards with 1940's "A's" to adapt it over. The only thing is the timing gears, and fan shaft gears should be match sets.
