Compression Test
Tom in Mich
09-04-2001 08:38:40
I have a 50 model B gas. When doing a cylinder compresion test, what should I expect the number to be? I did one this past weekend and the cylinder on the mag side read 65, the flywheel side read 50. This was performed as the manual said , clutch disengaged and the throttle opened slowly.
rollo
09-05-2001 05:18:28
 Re: Compression Test in reply to Tom in Mich, 09-04-2001 08:38:40
John and Ralph are right. You have bad rings or valves. You can confirm the ring problem by squirting some motor oil in the cylinders and starting it up. If the compression is higher, the rings are bad.
John
09-04-2001 21:16:58
I'm only a 14 year old who is constently in the barn, but I would have to say you need a valve job done because it shuldn't have that much of a gap in th compression. We have a few tractors we build for pulling, and if you don't have the valves seating good, you loose a good power percentage.
Ralph
09-04-2001 19:57:07
Those values sound low! to me. I bought my first compression tester this spring, got 120 - 125 psig on the starting engine (820). Something less than 100 on my A. The latter needs an overhaul. The mechanic that helps me took the starting engine apart and ground the valves, new rings and honed the cylinders. Also replaced the crank which had a crack, probably due to oil cutoff due to incorrect installation of the rear main. The cranking engine was drooling a bit at the exhaust, but I swear, he can smell trouble on a Two Cylinder.
