Carb manual for JD H?
Kilian
09-04-2001 07:49:42
I am wondering if there is a manual for rebuilding the carb on a JD H?
Would the JD SM2000 manual cover the correct DLTX-26,46 carbs?
Finally, where do I look on the carb to tell if it is a DLTX26 or DLTX46?
Thanks!
Frank
09-04-2001 19:39:59
 Re: Carb manual for JD H? in reply to Kilian, 09-04-2001 07:49:42
SM 2000 is the correct manual. Carb model number is on the right side near the front. DLTX26 is the all fuel carb. DLTX46 is for gasoline.
Hope this helps
Kilian
09-05-2001 15:29:55
 Re: Re: Carb manual for JD H? in reply to Frank, 09-04-2001 19:39:59
Thanks for the replies. I would imagine that my H has a DTLX-26 (haven't scrapped off the grime yet), as it was originally set up for kerosene and gas (two tanks).
I'm not too familiar with the dual fuel issue, but will it pose any problems for the DTLX-26 carb if the tractor is run only on gas?
Frank
09-06-2001 19:07:43
 Re: Re: Re: Carb manual for JD H? in reply to Kilian, 09-05-2001 15:29:55
I'm told it'll run just fine on Gasoline. I can't speak from actual experience since I haven't got mine running yet. If you want some real advice on these old JD 2 bangers, read Clooney's posts. The man is a goldmine of knowledge.
Will H.
09-04-2001 19:33:38
I'm not aware of a manual that covers rebuilding the DLTX 26/46 carbs. Robert's Carburetors has videos on rebuilding DLTX carbs in general, but it's really a simple job of dismanteling the carb, thoroughly cleaning( bead or sand blasting, cleaning all passages) and reassembling with new gaskets, neadle and seat, probably throttle shaft bushings and whatever else is worn or broken, and setting the float to a level position when inverted. Really doesn't matter if it's a 26 or 46, however the number is above the choke shaft near the air intake on the inside of the carb as mounted on the tractor. E-mail me if you need details.
