Engine Smoke/Wayne in TN
tom
11-26-2003 14:13:20
Wayne,
I noticed in a recent post you told someone regarding their engine "if it ain't broken, don't fix it", which is applicable to a lot of things.
You mentioned "is the engine smoking?"; do you mean the type of smoke coming out of the exhaust and/or the oil breather cap?
My MT only has colored exhaust when I first start her up, then she burns clear/clean from the exhaust thereafer...since I am in a complete restore mode, I never put the hood or grille on...as a result, I notice a small but constant amount of smoke coming out of the oil breather cap...is this normal? I do not think I would ever have seen it with the hood on...
Thanks for your comments,
tom
Wayne in Tn.
11-26-2003 16:40:16
 Re: Engine Smoke/Wayne in TN in reply to tom, 11-26-2003 14:13:20
Tom, Yes I was referring to exaust pipe smoke and breather cap smoke or (blow-by) Those Dubuques are known for some black smoke out the muffler, just depends on where you have the load needle set and condition of carb. This smoke is nothing to worry about. But white smoke out the muffler, can mean water getting into the combustion chambers. Blue or grayish smoke means ring or cylinder wear. Smoke out the breather cap means the oil rings are letting some blow-by get past them. If there is excessive blue or white smoke out the muffler or breather cap, its time for an overhaul. But in your case, smoke when first starting up, then runs clear, can mean the valve guides in the head are worn. Sometimes just removing the head and take it to a machine shop for a checkup and valve grinding, will help. If the guides are not worn too bad they can be knurled, also I always have my machine shop guy to install the Chevy umbrella seals on the valves. Also I have him to surface it. This will stop the start-up smoke. I know that those engines did not come with valve seals, but the Chevy seals added, work perfect. In my area, all this only costs $50 or so at the machine shop, unless you have to have new valves or guides.
tom
11-26-2003 17:21:05
 Re: Re: Engine Smoke/Wayne in TN in reply to Wayne in Tn., 11-26-2003 16:40:16
Thanks Wayne.
Happy Thanksgiving to you,Jenny and your family...and Happy Thanksgiving to all the rest of you YT-popping johnny restorationists and your families.
Best Wishes,
tom
