70
rustyr
09-03-2001 17:44:06
I wonder why my 70 doesnt show a temp rise? I know the guage is good. There is coolant near the probe. If it was a thermostat problem,wouldnt it more likely show a high temp? what about the pump? How can i tell if the coolant is circulating as it should?
thanks
John
09-04-2001 21:57:28
 Re: 70 in reply to rustyr, 09-03-2001 17:44:06
If the thermostat is not closing, then the coolent isnt having to seal with a hole lot of restriction to heat it up. Also, if its a diesel, they usually run a little coolerthan a gas.
poorerbut
09-04-2001 08:03:37
Possibly the thermostat could be stuck open (or
possibly not installed). Mine runs a little cool
until actually working, then runs about 160-180.
You should notice a temperature rise fairly quick-
ly if the pump wasn't working. I don't know an
easy way to verify the gauge. pb
