60 slinging oil
d walker
09-03-2001 11:11:31
i have a jd 60 that is slinging oil from behind the clutch pulley. anyone know if there is a oil seal or packing to be replaced and how much trouble is it to replace. still use the old tractor to cut and bale hay. need to repair as soon as possible. thanks davy walker
John
09-04-2001 22:06:57
 Re: 60 slinging oil in reply to d walker, 09-03-2001 11:11:31
yes, ther eis a packing in there somewhere near the edge of the reduction gear housing. In order to get to the packing, you have to slid out the wheel and pull off the belt pully itself. I haven't had the oppertunity to work on a 60, but on an a, I think you have to pull off the reduction gear housing itself to get to it.
P.S. You might eant to check the "C" piece and the gaskets in there for leaks. Also, if you do take off the reduction gear housing, check the main bearings and tighten them a little.
John, 14
