Hey Clooney
Skip
09-03-2001 06:45:58
I figured out why I had no oil pressure. Some dummy had tightened the oil filter cover so tight that they had broken the cast iron filter cover housing inside the block. The steel stud had pulled a chunk of the housing right out leaving a big hole. I welded the housing and retapped the hole and all seems well, but I forgot what the rod and head torques were could you give them to me again. Thanks Skip
Clooney
09-03-2001 09:04:34
 Re: Hey Clooney in reply to Skip, 09-03-2001 06:45:58
Skip, are we still working on the 51 B? Or is it something else?
Skip
09-03-2001 09:34:39
 Re: Re: Hey Clooney in reply to Clooney, 09-03-2001 09:04:34
Yep still the 51 B.
Clooney
09-03-2001 15:23:09
 Re: Re: Re: Hey Clooney in reply to Skip, 09-03-2001 09:34:39
Skip, head= 96'lbs (torque in 10 lb increments from the center out)....rod's= 63'lbs.
Skip
09-04-2001 17:51:07
 Re: Re: Re: Re: Hey Clooney in reply to Clooney, 09-03-2001 15:23:09
Thanks Clooney I don`t know how you keep everything you know inside one head but you sure are a help. Thanks again Skip
