730 hp
David A Brockle
09-02-2001 20:13:00
How much horsepower can you build in a 730 gas? Can I get 80 hp?
Paul
09-05-2001 19:13:11
 Re: 730 hp in reply to David A Brockley, 09-02-2001 20:13:00
I have a stock John Deere 730 diesel. We use it to mow and what ever else needs done, but a few weekends ago I too it to the local fair to see what she would do. I think it is rated at 70hp, but the local Ford tractor dealer had a turned up ford 7000. He said it was puting out about 95 hp. Well the 730 ate that ford alive. I am not all into putting all that money into the tractors, thats why I don't pull because of people who stick all that money into them. How can I compeat with these guys? I think that you guys are takeing all the fun out of it. Just my 2 cents worth.
John
09-04-2001 20:39:36
Yes, You can get alot more, like about 110hp if you send alot of parts in to machine shops.
In bay city, Michigan, you can get the crank stroked and the block bored and ringed.
Gpower
09-03-2001 10:09:59
Yep you can, depends on how deep your pockets goes
David A Brockley
09-03-2001 12:51:58
 Re: Re: 730 hp in reply to Gpower, 09-03-2001 10:09:59
Tell me more. Mine is a good stock tractor but might want to get it up to peak and pull agains't some good "Gs"
G Taylor
09-03-2001 14:44:11
 Re: Re: Re: 730 hp in reply to David A Brockley, 09-03-2001 12:51:58
While higher ground speed will help coast the sled farther there are other priorities. A perfectly ballanced tractor at max weight for the class, max height on the drawbar & the rear tire condition. No matter what HP you have if the size,pressure,rim width, tread style, bar height,angle & sharpness isn't right. Someone else in 1st gear & a stock engine is going to outpull your machine.
