Early-styled B crankshaft
ryan
09-02-2001 19:14:54
I'm restoring a 1947 long-hood B, I need to take the crankshaft out to get it ground but I'm not sure how. Do I have to take out the clutch assembly and reduction gear thing? Any help for this 4-H project would be helpful. Thanks
John
09-04-2001 22:30:06
 Re: early-styled B crankshaft in reply to ryan, 09-02-2001 19:14:54
To get out the crank, you hteak the flywheel off, the belt pully, the main bearings, oil lines going to the main bearings, and the reduction gear housingtaken off, then you should be abel to take the crank out the belt pully side.
Ron Stephens
09-03-2001 04:55:08
Ryan,
You need to get a hold of the service manual. Will make your project go a lot smoother. The original through John Deere is still available or you can get an aftermarket IT manual. The IT manual will be a lot cheaper and should answer most of your questions.
Stephens Farms
Ron Stephens
3328 Rice Road
Dunkerton, IA 50626
