Headlamp reflective surface, needs restoring
Scott
09-02-2001 18:44:36
I have 6V headlamps for my 1941 B, but the reflective surface has broken down so badly. I would like to find out if there is a way I can make a new reflective surface, or what kind of business fixes these reflective surfaces to be as close to new as possible -- looking to get more light on the subject :)
chris
09-05-2001 01:27:46
 Re: Headlamp reflective surface, needs restoring in reply to Scott, 09-02-2001 18:44:36
if they're just dim, try steel wool on the reflector. I thought my light was shot too, then I realized there was a sort of "clear coat" on the reflector, which I buffed off with some 0000 steel wool, and sprayed on some clear laquer. Good as new, if you ask me....
chris
Jerry S
09-04-2001 12:41:15
There are some ads in the Hemmings motor news magazine that sell resilvering material for do it yourself'ers. Supposedly makes them like original for any kind of automotive or tractor restoration purpose.
Larry E
09-03-2001 16:26:22
Stephens equipment co. at Franktown CO. has any new part needed tofix lights ,beats doing a half assed job with a can of spray paint
G Taylor
09-03-2001 14:46:07
Home furnature shops that restore mirrors by recoating the silver reflective surface with new silver works wonders.
Craig
09-03-2001 06:36:25
Call Dave Cook in Wisconsin. I think he's the guy who has them replated. Phone (715) 373-2092. I think they are about $20 each exchange.
They are beautiful. Just like from the factory.
L.C.
09-04-2001 21:08:35
 Re: Re: Headlamp reflective surface, needs restoring in reply to Craig, 09-03-2001 06:36:25
I have one of those reflectors on a 420C and am well pleased. Thanks for posting the phone #...I need to give him a call about replacing a terminal on a lamp body.
KWB
09-03-2001 04:40:27
I found some shiny metal tape at an automotive parts store, about 2 1/2 inches wide. this is basically the same idea as using aluminum foil, but easier to apply. It's not as shiny as having them rechromed, but works for me.
Norman
09-03-2001 04:18:15
Scott, They sell small cans of silver paint at the parts house. Works for me. Later
Norman
---===] jer[===---
09-03-2001 00:27:23
It depends on the condition of the light reflectors. And if you need the tractor to be exactly correct in every respect. There are people whe will plate the silver back onto the parabalic surface. Otherwise, you can do as I did, stretch aluminum foil onto the inside of the reflector. The light output is increased, and the cost is low, but it is not perfect. Hope this helps.
---===] jer [===---
