3010 trans stuck in gear
bud
09-02-2001 17:57:01
have a 3010 sinc range worked great then got stuck in one gear now it locks up in all the others it also will not go into reverse and even in park it stalls out shifter seams to be ok i think its stuck in second or third maby someone can tell me what to look four when i split it thanks
Iowa Farmer
09-03-2001 11:19:05
 Re: 3010 trans stuck in gear in reply to bud, 09-02-2001 17:57:01
There is a roll pin in the syncrorange up in the dash there and iut shears every once in a while. That may be doing that. CHeck that out before you go to splitting it.
Gary
09-04-2001 15:13:59
 Re: Re: 3010 trans stuck in gear in reply to Iowa Farmer, 09-03-2001 11:19:05
Hey Iowa Farmer,
Talked to you on the chat board the other night. Enjoyed what time I could spend chatting. I just saw the comments you made on the roll pin. I am just wondering if my 3020 has the same roll pin because it has been doing some wierd things as well. Give me an email back when you can([email protected]) and thanks a million
Gary
