3020 hydraulic leak
Terry
09-01-2001 17:38:50
My 3020 has started leaking around the input shaft.Is it possible to replace it on the tractor. Thanks
twopop
09-03-2001 10:16:15
 Re: 3020 hydraulic leak in reply to Terry, 09-01-2001 17:38:50
if your talking about the main hydraulic pump,then yes it is possible to change it on the tractor,but it will be quite difficult unless you have the jd tools needed.you can remove the drive shaft and screw small sheet metal screws into the seal and pull the seal out.there should be a snap ring that has to be removed first.a small piece of pipe can be used to set the new seal.
