B starts but doesn't stay running.
Karl Bader
09-01-2001 15:39:23
I can say that my B finally started. that's about as far as I got. When it starts the engine revved really high and then after a few seconds would cut out. The smoke when the B starts is white. I suspect that it is a carb problem, the idle screw is open about a turn and a quarter, the high speed screw about the same. when I pull the throttle it revvs even higher. What should I look for and try? My battery died so I won't try again till tomorrow when it recharges again. Please help!
Thanks,
Karl
Chuck
09-02-2001 04:51:52
 Re: B starts but doesn't stay running. in reply to Karl Bader, 09-01-2001 15:39:23
Karl, wish you were closer to my area, I'd help you get the B going. I've had a bunch of them. Most of the time they're not much trouble. If you can get a hot mag or good distributor you're generally ok. The original JD distributors were worthless. Hope you don't have one of those. If so I'd ditch it and go to a later model Delco and even add electronic ignition. I've got 4 tractors and have electronic on all of them. You got some fire power to burn this poor quality gasoline. Need a clean carb and you should be in business. If you're overreving you engine, you'll be replacing the governor weights. Keep chasing down the problems and eventually you'll have them all solved but remember, it's a HOBBY.
