5020 Loader
Randy Gies
09-01-2001 09:42:46
I recently bought a John Deere 5020 with cab and loader. The loader hyd is plugged into the remote hyd ports. With this set up I can not use the remotes with out unplugging the loader. Isn't there a different place to run the hyd for the loader?I do have the JD service manual but can't find anything. I'd appreciate any advice.
Randy Gies
09-07-2001 09:26:20
 Re: 5020 Loader in reply to Randy Gies, 09-01-2001 09:42:46
Thanks for all the input. Great to find a place to ask all the differant questions!
The Stranger
09-01-2001 17:14:39
There is a way to tap into the main hydraulic system, but then you will have to some re-plumbing and buy hydraulic valves. Call Ed Beem at 712-876-2275, he can fix you up, or tell you what you need to do.
Steve ii
09-01-2001 13:15:15
hello, what kind loader is that? I have a JD 4000 with a Daul loader every thing seem working good, there been no problems.
Lloyd Strickland
09-01-2001 12:05:21
I`ve had loaders on 4020`s for years and were always plugged into remotes. There is no other hookup to my knowledge.
Doug in Il.
09-02-2001 06:11:59
 Re: Re: 5020 Loader in reply to Lloyd Strickland, 09-01-2001 12:05:21
This is easily done. You tee into the pressure line coming to the back of the tractor right after the fitting that takes oil to the power steering. Then, you buy from John Deere, or make a ported hyd. oil filter cover and run the return line to that. This way you can use an independent valve for your loader. Just make sure the independent valve is set up for a closed center hyd. system. I have 2 tractors I set up this way.
Apple
09-05-2001 20:00:35
 Re: Re: Re: 5020 Loader in reply to Doug in Il., 09-02-2001 06:11:59
I did the same works great. Frees up the remotes.
