3010 3-pt
Mike
08-29-2001 20:35:47
Is there any adjustment to slow down the rate of drop of the 3-pt hitch on a 3010 with a bushog attached?
JD70Jim
08-30-2001 06:37:01
 Re: 3010 3-pt in reply to Mike, 08-29-2001 20:35:47
Mike:
While I don't have the OM for a 3010, I do have one for the 4020 and 3020. The adjustment for speed-of-drop is done through a throttle valve located on the rock shaft piston cover.
"to adjust the throttle valve, loosen the lock nut and turn the threaded valve stem in to decrease speed-of-drop or out to increase it. Tighten the lock nut when the speed-of-drop is correct."
If there were any significant changes between the hydraulic systems, it may have been different for your tractor, but somehow I doubt it. Having an OPERATORS MANUAL would solve this problem for you.
