B brake bushings
wllarson
08-28-2001 21:31:53
On my 39 B, the brake peddles are loose. I asked my JD dealer to order the bushings. My brakes have the hood and he says there are no bushings on these brakes. is this so?
chris
08-29-2001 21:26:03
 Re: B brake bushings in reply to wllarson, 08-28-2001 21:31:53
Be glad you don't have any brake bushings. those things cost a FORTUNE from the deere dealer!
chris
Clooney
08-29-2001 12:44:33
wllarson, the 39- J.D. B doesn't use bushings in the housings for the pedal shafts. You will either have to machine the housings for a bushing, build the pedal shaft up, or shim the pedal to housing with a hardened washer to eliminate the play. The excess play doesn't seem to hurt anything, but it is annoying.
Theman
08-29-2001 07:41:34
The brakes on my '35 B had both inner and outer bushings. Had to have a machine shop make replacements and now the chatter is gone. It turned out that the noise was a washer between the shaft nut and pinion in contact with the bull gear teeth. Also make sure your brake shaft isn't worn too bad. Keep your brakes in good repair.
