B/JD
Bob
08-28-2001 11:40:09
Hello..I have a chance to pick up a 40's B..for 450/500. The fellow says it runs, but the "water pipe" is leaking inside the engine. Am I missing some thing here,or what? Thanks for any information Bob/Mn.
al
08-28-2001 12:30:34
 Re: B/JD in reply to Bob, 08-28-2001 11:40:09
He is probably talking about the push rod tubes which are in the head, a fairly common problem. The replacements are made of brass so they last forever if someone doesn't run the manifold studs down into them like they did on my '39 A.
If this is the case there will be water in the crankcase so the amount of engine damage could be considerable.
Bob
08-28-2001 18:33:54
 Re: Re: B/JD in reply to al, 08-28-2001 12:30:34
Al; Thanks a lot for the quick reply! Yes that makes sense...I'll ck it out close tomorrow, when I go to look at the B. Bob Mn
