JD 60 skipping a beat
Al
08-27-2001 20:26:01
I got Pop's 60 out last weekend which has been sitting for a few years. I drained the gas tank, put in new plugs and she fired right off. The problem is that the right cylinder skips. It looked and FELT like it had good spark. I didn't have a compression tester but the valves are working fine. It seams like it loads up with fuel and then pops with both when you drive it. I thought that I had an ignition problem. Could it be a fuel problem? I read the archives and poorerbut recommended AC C88L plugs. Are they that much different? Thanks Al
max
08-29-2001 06:21:32
 Re: JD 60 skipping a beat in reply to Al, 08-27-2001 20:26:01
Replace your condenser and points-I had a similar problem with a 60-particularly under load.
Al
08-29-2001 16:42:51
 Re: Re: JD 60 skipping a beat in reply to max, 08-29-2001 06:21:32
Thanks Max. Points are pretty cheap to install. Why would it fire fine on #1 piston and miss on #2? The same points send fire to both cylinders. I guess that new points solved your problem? Al
