'63 (high Serial no.) JD 4010 Diesel Value???
Iowa Farmer
08-27-2001 18:03:35
Hey guys, I was just wonderin what a 4010 Diesel was worth. It has less than 100 hours on complete overhaul(it has a whole new block, so everything was checked out) The Front Hyd pump was Overhauled at the same time. I have had the tractor split, Installed new Pto pins and All new gaskets, needle braerings, gars were checked, they were fine. It has 2437 hours, I dont know if that is true, but It very well could be. The previous owner bought this tractor in early '64. He bought it new. He purchased a new 4320 soon after and the 4010 never saw much work in its later life. The previous owners son got on it one day while his dad had the coolant drained and run it without any coolant one day in the winter, hence come the new block. It has all 4020 guts. The tin is purty straight. Needs rubber, and one rear rim fixed however. Just curios as to what it is worth. Thanks!!
john2510-3020
08-29-2001 16:24:15
 Re: '63 (high Serial no.) JD 4010 Diesel Value??? in reply to Iowa Farmer, 08-27-2001 18:03:35
ohhh i would saay around about 3000!!!lol no if its been repainted then it would bring about 6000 or so buit thats just here in missouri too... since it has the turbo the 4020 guts and such then it might bring more. but then the new tire and rim could suck the value down right quick. you dont do much talking no mores neither why? well ttyl! and have fun!
john2510-3020
