JD 'D' flywheel breaking-Typical or not?
dan
08-27-2001 16:49:33
Do 'D' flywheels break or crack or is it uncommon on a model 'D'? Thanks.
Don E. Foster
08-27-2001 17:16:42
 Re: JD 'D' flywheel breaking-Typical or not? in reply to dan, 08-27-2001 16:49:33
It is my understanding that the '26 D had 3 different flywheels. First the original spoker, then they made a disc with a small hole for give for clamping to the crank. Apparently this too small hole caused the wheel to crack so they made a disc with the larger hole and it worked. Do you have a '26???
dan
08-28-2001 06:35:32
 Re: Re: JD 'D' flywheel breaking-Typical or not? in reply to Don E. Foster, 08-27-2001 17:16:42
Hi Don, no I do not have a '26. I was thinking more along the lines of a styled D. On occasion you hear about the 70 with a bad flywheel and I was wondering if the styled D ever had such a problem or if it rarely happened.
Shorty Dear
08-30-2001 18:11:45
 Re: Re: Re: JD 'D' flywheel breaking-Typical or not? in reply to dan, 08-28-2001 06:35:32
Dan,
I don't think the styled D's had a flywheel problem. I have a bunch of parts D's on my lot and not a cracked flywheel on any of them.
