Adjustment of John Deere A Clutch
Ross Boots
08-27-2001 15:12:17
Can anyone tell me how to adjust the clutch on my 1949 John Deere A? Thanks -Ross
JD70Jim
08-27-2001 19:41:56
 Re: Adjustment of John Deere A Clutch in reply to Ross Boots, 08-27-2001 15:12:17
Your owners manual has a pretty good description of how, and it has pictures.
Tony
08-27-2001 19:35:56
It seemed to me that on my grandpas B John Deere, you took the cover off, removed some cotter pins, and tighten something, i can't remember, is it the same with the A?
Leroy
08-27-2001 17:26:22
Engage clutch lever and tighteneach of the sloted nuts a flat at a time.Tighten sloted nuts until clutch goes into engaged position with a snap. A pull from 70 to 90 pounds should be required on end of lever to engage clutch.
Ross Boots
08-27-2001 18:42:46
 Re: Re: Adjustment of John Deere A Clutch in reply to Leroy , 08-27-2001 17:26:22
I'm no too familiar with clutches. Is engaged when the clutch lever is ahead or back? And by "flats",what do you mean? thanks -Ross
Leroy
08-27-2001 18:56:51
 Re: Re: Re: Adjustment of John Deere A Clutch in reply to Ross Boots, 08-27-2001 18:42:46
You push the clutch lever forward to engage the clutch. The nut has 6 sides a flat is one of those 6 sides.
