Hyd. bucket installed on 45W loader/720 tractor.
PaulCtOH
08-24-2001 06:33:13
I used a 6'bucket off a Case 580CK; two 3"x24" cylinders from Quality Farm; two spool valve from TSC-open center with float. I hooked the lift cylinders up for double acting. Down pressure must be bypassing in the cylinders since it won't raise the front of the tractor. But, that's ok with me.
Putt Putt
08-24-2001 13:44:44
 Re: Hyd. bucket installed on 45W loader/720 tractor. in reply to PaulCtOH, 08-24-2001 06:33:13
Paul---
I use almost the same setup. Not every post has to be a question. Thanks for sharing your idea.
PaulCtOH
08-24-2001 14:19:28
 Re: Re: Hyd. bucket installed on 45W loader/720 tractor. in reply to Putt Putt, 08-24-2001 13:44:44
I had posted here last winter seeking advise .I appreciated the helpful posts. So, I thought I would just return the favor in case someone else might be contemplating such a project.
BK
08-24-2001 11:39:51
So What!
